I have sonoff WiFi switch which I’ve linked to the app.
I can create a timer, but I don’t see the option for loop timer?
I’m on iOS
Is this function not supported on iOS, or it a Sonoff issue ?
I’m on iOS
How about other devices? It may be that this one has no looping option, or you may need to set it separately for each channel. Try touching the 3 dots at the top.
BTW, which device is it?
Only have this device for now. Not sure if it’s because of two channels - but I seperated them and still have the issue.
Going to buy a sonoff single switch and see if persists.
I assume you have sonoff ? But on android?
Right, on Android. But it looks the same. My friend uses it on iPhone, so I had many occasions to compare.
