Looking for a Zigbee alarm/siren, that is fully compatible with ihost
I’m looking for a recommendation on a Zigbee alarm or siren that is fully compatible with iHost mainly because I do not think sonoff makes one yet.
I have sonoff motion sensor (SNZB-03P) and want an alarm/siren to work with it over zigbee even when internet connectivity is lost.
Any ideas?
Thanks in advance!!
I’m not aware of one, but you could turn on or off a cheap alarm with a Zigbee Switch. That is probably what I’d do.
Thank you so much for your answer. Can you please recommend a any siren then? There’s a good idea I will connect it with a zig on off switch and activate it via switch
I have never personally made an alarm so can’t say one that definitely works. The iHost has a speaker built in but if not enough this is the first on Aliexpress I found:
https://a.aliexpress.com/_EuJdxRq
Most Sirens will work on DC low voltage but that has a 230V AC option.
I think to get free shipping you need to get to $10 so maybe get the Zigbee switch at the same time.
This is more expensive but I was thinking about trying the Woox siren.
It has a battery backup which probably could be used in Node-red to detect when there has been a power outage when away from home. The capability exists and in Smartthings can be used to trigger a routine.
I have done that. I connected an old siren to a zigbee plug. Other option is to use Alexa or Google Home but this won’t work if there is no internet.
