Hi
I was curious about the Wi-Fi signal strength of my devices, as I had some problems - I already solved it.
However, I noticed that if I only use the devices in LAN mode (all enabled), some of them refuse to provide RSSI data, interestingly, if I enable CLOUD mode, the missing data comes…
The same is true for the INCHING and INCHING DURATION setting options as well as for turning the LED on and off.
My goal would be to create an independent, stable and secure local control (Thin Client + HAOS) and it would be nice to see this data as well as use INCHING.
Devices used: THR316 and THR316D, MINI, RFR2, RFR3.
Could it be fixed in a future update?
