I have a TOMZN 63A circuit breaker with energy monitoring, in the app identified as PSF-B67-GL.
The issues is that it regularly records energy consumption that is just impossibly high - it regularly (but not exclusively) does this in the night hours when actual consumption is actually low.
For example, this is the January consumption log, reporting a sum of 1035 kWh:
For reference, the utility company bills me 219 kWh for the same period - so this is not a small difference.
The corresponding Home Assistant graph with the wattage underneath (daily Energy (top graph) is calculated somewhat different than the eWelink app, but it is generally consistent with the data in the app so good enough for reference):
So what is visible is that there are spikes in the wattage and energy usage reported at times, and I can’t figure out what is causing these spikes that are clearly physically impossible (way over the rating of the device or anything that could consume this much). The Amperage reported do not seem to have the same spikes and is a consistent graph.
Can anyone help figure out what is going on? Is this a faulty device or an app issue?
