Impossible to add a 2nd timer to execute a scene
hello
Currently every time I want to add a 2nd timer to a scene, I get the pop-up message at the top “Timer has been added as triggers”
And therefore no other timer is added.
It’s a bit annoying because I want a scene that triggers an action several times a day and that forces me to do several scenes.
Possible in the next version?
As a temporary solution you can try using https://sequematic.com/
Yes I’ve had the same requirement for some time for iHost. Mine is to run a scene at 59 minutes past each hour to switch all of my radiator valves from whatever state they may be in at the time to AUTO. I did raise the issue but so far no solution. I just wrote short 24 scenes to trigger tap to run scenes that achieve the sequences that I need- it’s easier to modify a few tap to run scenes than a shed load of auto scenes.
