iHost strange behavior
Does anyone of iHost users ONLY has this strange behavior on some timer issue in a scene generated on iHost between 00:00 and 00:59?
Since version 1, I have a scene that was set to trigger at midnight (00:00H) and works fine. If I try to EDIT this scene, and with or without making changes, on clicking “SAVE”, the execution time 00:00 changes to the time the “SAVE” button as been clicked. The scene will now be executed on the save time. This appening to all scenes starting at “00:**H”, no matter the scene name.
This bug has been reported many time to eWelink but they can’t reproduce this issue.
Try it on your system and give a feedback if you have the same issue!
  1. Make a new scene
  2. in IF section: Make it a Timer setted to “00:**” ( ** = minutes)
  3. in THEN section: Make it do what ever you want
  4. SAVE your scene
  5. Come back and try to EDIT your scene, except the time. No editing will do the same.
  6. Watch the behavior of the setted time, when pressing the SAVE button. If it’s too fast, try to re-edit and check if your timer is still “00:**”
Thx for the feedback.
Our team has identified a bug in this, a fix is coming.
This issue as been fixed by eWelink, in iHost version 2.4.1
