Hi. I am again facing the same issue again. Connection to all zigbee devices is lost. LED light on iHost is still blue. As noted earlier, this is happening every other day which is solved by turning off the iHost for about 30 minutes and turning it back on.
hi, do you have any add-ons installed? are they working well?
another question, do you always need to wait for hald an hour before power on iHost? if you just reboot it will the devices reconnect?
please enable system log in iHost settings, and submit the logs via the feedback button, we’ll try to analyze.
This issue has happened again. Yesterday I updated my iHost to 1.5.5.
The Zigbee connection was lost earlier today. However, I was not able to restore the connection by powering down iHost for a while and turning it back on. Even after a reset, red light is still flashing and it’s not pairing with any Zigbee devices. The add-ons in docker are working well. My only issue is with the Zigbee Coordinator in iHost. I will be sending system logs again via the feedback in iHost settings. Is there a chance that this is a hardware issue?
