And where can I set my wifi details?
There’s nothing to fill, a windows apear and disappear fast(cant see content) and No wifi Available message appear… no wifi creditals input no nothing…
Found this in logs:
- {“success”: false, “reason”: “Wlan Not Found”}
- wifi init state is false
2024-08-29 10:58:21.251 INFO [wifi-app:1098:main.c:main:62] @@@@@@@@@@ APP START @@@@@@@@@
2024-08-29 10:58:21.251 INFO [wifi-app:1098:main.c:main:63] wifi-app based on librkwifibt.so v1.6
2024-08-29 10:58:21.281 INFO [wifi-app:1098:wifi_mqtt.c:on_connect:445] MQTT connect success, ClientId: wifi, UserName: wifi
2024-08-29 10:58:21.281 INFO [wifi-app:1098:wifi_mqtt.c:on_connect:460] publish online message success, payload: {"online":true,"reason":"Startup"}
2024-08-29 10:58:21.281 INFO [wifi-app:1098:wifi_mqtt.c:on_connect:478] subscribe multiple topic success
2024-08-29 10:58:58.859 INFO [wifi-app:1098:wifi_mqtt.c:on_message:508] ++++++++++++++++ RECV MQTT message ++++++++++++++++
MQTT topic: wifi/system/enable
MQTT message: {"enable":false}
2024-08-29 10:58:58.860 WARN [wifi-app:1098:wifi_mqtt.c:handle_wifi_enable:122] wifi has already been deinit
2024-08-29 11:17:40.037 INFO [wifi-app:1098:wifi_mqtt.c:on_message:508] ++++++++++++++++ RECV MQTT message ++++++++++++++++
MQTT message: {"enable":true}
2024-08-29 11:17:40.043 INFO [wifi-app:1098:wifi_mqtt.c:handle_wifi_enable:115] --> enable wifi function
2024-08-29 11:17:40.077 WARN [wifi-app:1098:rk_wifi_api.c:rk_wifi_open:568] RK_wifi_enable 1 fail!
2024-08-29 11:17:40.077 INFO [wifi-app:1098:rk_wifi_api.c:publish_init_state:122] publish initialization state success, payload: {"success": false, "reason": "Wlan Not Found"}
2024-08-29 11:18:07.500 INFO [wifi-app:1098:wifi_mqtt.c:on_message:508] ++++++++++++++++ RECV MQTT message ++++++++++++++++
MQTT topic: wifi/system/scan
MQTT message: {"timeout":180}
2024-08-29 11:43:10.487 INFO [wifi-app:1098:wifi_mqtt.c:handle_wifi_enable:115] --> enable wifi function
2024-08-29 11:43:10.511 WARN [wifi-app:1098:rk_wifi_api.c:rk_wifi_open:568] RK_wifi_enable 1 fail!
2024-08-29 11:43:10.511 INFO [wifi-app:1098:rk_wifi_api.c:publish_init_state:122] publish initialization state success, payload: {"success": false, "reason": "Wlan Not Found"}
2024-08-29 11:43:28.869 INFO [wifi-app:1098:wifi_mqtt.c:on_message:508] ++++++++++++++++ RECV MQTT message ++++++++++++++++
2024-08-29 12:21:45.531 INFO [wifi-app:1082:wifi_mqtt.c:on_message:508] ++++++++++++++++ RECV MQTT message ++++++++++++++++
2024-08-29 12:21:45.531 WARN [wifi-app:1082:wifi_mqtt.c:handle_wifi_scan:144] wifi init state is false
*A moderator has edited this post, adding a code chuck for readability.
Hey, sorry for the late reply,
It suggested your iHost may have a hardware issue; please contact SONOFF for further support.
Thx in advance.
[quote=“teo.alex, post:459, topic:16376”]?
[/quote]
My ihost version with 4GB RAM also has this problem.
Hey,
As I mentioned above, please contact SONOFF on this issue.
Nice. After more then 1 year I found out that my ihost is foulty… but that foulty part was disabled so I didn’t know earlier…nice. good job itead for selling disabled foulty parts…
Not necessarily faulty. There may be other reasons. That’s why @ward refers you to Sonoff. If it is indeed faulty, it happens to everyone. You would simply have discovered it much earlier.
Sorry for the inconvenience.
It might be damaged during daily usage, such as frequent power outages, or had it flashed some unofficial system.
May I ask if you have contacted SONOFF? If so, please DM the ticket number.
Yes I did… I’ll send you ticket number… no answer until now…
Give the guys some time. There are many customers in need.
Hi, yes i did. Reboot, unplug, stop wifi start wifi…etc, nothing… still no wlan in logs
ok.
did you get a ticket number for itead tech support? I only got an email with feedback that they saved my ticket.
Yes I have a ticket. I think that there are many tickets, big update=big problems.
BT connection it’s working, bot wifi not. I have a 4Gb version. WIFI and BT are on same module RTL8723, so I think it’s a software problem not a module problem.
They are but it doesn’t prove it’s a software problem.
Hey
Please contact SONOFF for help.
Thx in advance.
Unfortunately, I have a problem with iHost 4GB.
I don’t understand why a wifi connection is needed if initially everyone connected IHost via Lan. If only they had made IHost as a wifi router…
