Is Chrome a reliable browser to use with iHost ?
Chrome ver Version 136.0.7103.114 (64 bit)
IHost ver 2.5.2
Ikea of Sweden TRETAKT ver 2.4.25
Firefox ver 138.0.3 (32 bit)
Using Chrome browser we have noticed an issue regarding the iHost display card for Ikea of Sweden TRETAKT switches that are controlled for On and Off by iHost scenes.
For example if an iHost scene is holding a TRETAKT switch in the OFF condition and the Turn On/ Off slider of the iHost Home Screen Card for the device is moved to the ON position the device will switch ON but under the control of the scene it will immediately toggle back to OFF, however the slider indicator of the iHost card will remain in the ON position until F5 is pressed. The same is true in reverse for an iHost scene holding a TRETAKT switch in the ON condition.
This issue does not manifest itself when using Firefox Browser.
Thanks for your feedback! We have not received reports of this issue before. Could you please provide some screenshots or a video to reproduce the problem? Additionally, you might want to try clearing your browser cache to see if that helps. Thank you!
Thanks for your reply. Clearing the cache doesn’t resolve the issue. Included are screen videos of the 2 scenes controlling the TRETAKT #1 and what happens when the switch is manually operated from iHost Home Screen while the scenes are enabled. It was necessary to press F5 to have the iHost Home Screen Card for the TRETAKT #1 to show its correct On/Off value. This does not happen with Firefox
Hi, I can report that this also happens with another Zigbee device: IKEA of Sweden TRADFRI ver 2.3.089 but WiFi devices do not seem to be affected. I have included a screen video of CH 1 of a Sonoff 4CHPRO WiFi switch being held in the OFF condition by a iHost scene with an attempt to switch it on from the iHost Home Screen card for the device.
