Hello has anyone had an issue with the camera ip address changing on the Ihost .
Every day or so the camera stops working and when I investigate I find the address has changed in the device settings but the camera still has the original address.
The only way of getting it working is to delete the camera and set it up again.
I have even tried carrying out a reset on the Ihost.
I was facing similar issues but after reserving my cameras ip and ihost ip problem did go away
I am still having the same problem with the cameras Ip address changing and the only way to resolve this is to delete the device than add it again.
That’s caused by the DHCP of the router, try to assign a reserved IP for the camera.
Hello. I have the same problem. Have you found the solution? I have set the camera addresses in the router.
Has anyone taught the Sonoff team about the ability of assigning static IP’s to hosts? It can solve a world of issues, including predicaments like this! Giving a static IP to the ihost would be a great start ![]()
