iHost app's in docker (matter server, matter bridge and more)
Since the developers removed their ARM-v7 compatible applications from hub.docker.com, I have created a repository with the latest versions of the removed applications.
I also created a Matter server (32-bit) for Home Assistant.
You can find all the applications in my repository: el404 (EL404)
They are available through search on iHost.
Currently, the repository contains the following applications:
  1. Matter server:
    Search: el404/ihost-matter-server
    Setup configuration:
    Network: bridge
    Port:
    5580:5580
    5581:5581
    5582:5582
    5583:5583
    Volume: matter: /data
    Go to:
    http://ihost.local:5580 (Web UI)
    Home Assistant Matter integration:
    ws://ip-your-ihost:5580/ws
  2. Matter Bridge:
    Search: el404/matterbridge-for-ihost
    Network: host
    Volume: matterbridge: /workspace/data
    Go to:
    http://ihost.local:8283 → Settings → Commissioning Port 5540 > 5541 → restart icon
  3. Home Assistant
    Search: el404/homeassistant-for-ihost
    Network: host
    Volume: HomeAssistant: /config
    Go to:
    http://ihost.local:8123
  4. File Browser
    Search: el404/filebrowser-for-ihost
    Network: bridge
    Port:
    1234:80
    Volume:
    FileBrowser: /srv
    and then all your application volumes, at the end add “-files”, for example:
    HomeAssistant: /srv/HomeAssistant-files
    zigbee2mqtt - /srv/zigbee2mqtt-files
    mosquittoConfig - /srv/mosquittoConfig-files
    Go to:
    http://ihost.local:1234
  5. ESPHome
    Search: el404/esphome
    Network: host
    Volume:
    esphome: /config
    Go to:
    http://ihost.local:6052
If you need another application, write here :wink:
It would be good to add a thermostat for iHost, as the developers do not plan to add this feature to iHost. According to the latest plan.
What do you mean? Where can I read more about this?
Heating control in the building. https://energysavingtrust.org.uk/advice/thermostats-and-heating-controls/
Are you talking about adding thermostat control support within the eWelink CUBE?
If that’s the case, it’s only possible for the eWelink team.
I thought, but Sonoff sometimes ignore the community’s requests. I’m replying a little late today because I’m currently developing hardware i am programing frimware.
BEWARE, I just tried to update the docker image for HomeBridge and it loaded a 64 bit version that is NOT compatible with iHost (as it is 32 bit only.)
