For this to work, I need to Matter Server in Docker. When I install Matter Server in iHost’s Docker, it fails to run. I am newbie and would like help in configuring the settings. Any help would be greatly appreciated.
HA needs a running Matter Server (Matter Add-on) for this integration. However, sadly, the official Matter docker image ONLY supports x64 chipsets (iHost uses a 32-bit one), so you may need to run this container on other devices you have and fill in the link to the tab you posted.
For further guidance on this, I would highly recommend you turn to the HA forum or their Discord where you would get more professional assistance.
Nothing has worked. As Ward, pointed out in the previous reply. iHost is built on 32 bit architecture which does not support HA’s matter server. I hope someone here can figure out a workaround.
