Help Us Prioritize 32-bit HA Add-ons and Shape Our 64-bit iHost Hardware
Hello everyone,
We’d love to hear your thoughts and ideas as we continue to evolve the iHost platform!
1. Supporting 32-bit HA add-ons
All current iHost devices run a 32-bit architecture, which means some Home Assistant add-ons that require 64-bit support aren’t compatible right now. However, we’re actively developing and maintaining versions of key HA add-ons for 32-bit platforms so you can keep using “HA over iHost.”
  • Which Home Assistant add-on do you most need on 32-bit iHost?
  • Let us know the name and any specific features you rely on, and we’ll prioritize it in our roadmap.
2. Upcoming 64-bit iHost hardware
Later this year, we plan to launch a new iHost model featuring:
  • 64-bit SoC for full compatibility with modern HA add-ons
  • Dual-band (2.4 GHz & 5 GHz) Wi-Fi
  • Expanded eMMC storage for more headroom
    We’re aiming to deliver a highly reliable, high-performance smart-home hub—tailored to your needs.
  • What features or improvements would you like to see in the new hardware?
  • Any thoughts on connectivity, storage capacity, power management, or other capabilities?
How to share your feedback
  1. Reply below with your top requested 32-bit HA add-on.
  2. Tell us your must-have features for the upcoming 64-bit iHost.
  3. Feel free to discuss and upvote other users’ suggestions.
Your input directly shapes our development priorities—thank you for being part of the iHost community!
One thing that would be interesting would be if the Ewelink addon or another addon could recognize the R5 controls that use the ewelink proprietary connection.
I think what should weigh the most is the lack of matter in HA and node-red. If these plugins were available, you could use the R5 controls together with HA and would probably put HA on iHost for day-to-day use.
Thank you very much for your feedback.
When you say R5, you mean “SwitchMan Scene Controller R5”? If you have already added R5 to your eWeLink account. The new eWeLink Smart Home Add-on will definitely support it (though maybe not in the first release). But it’s a long control link (from the R5 to the eWeLink Remote Gateway to eWeLink Cloud to eWeLink Smart Home Add-on to HA) which leads to noticeable control delay. The best way would be HA directly support R5 through BLE, right?
Matter Bridge Add-on is under developing, and we will release 32 bit Node-Red for HA over iHost in a few days (propably today).
We are also considering to bring other 64 bit only HA add-on, such as ESPHome Device Builder, OpenThread Border Router to HA over 32 bit iHost.
Hello! What about to connect S-MATE2 directly to HA? Currently I need to use an additional sonoff wifi device to connect S-MATE2 device to HA…
Yes, that’s it. The ideal would be for it to work locally, just like it does with iHost, without the need to use the cloud. That’s why I suggested that it work locally with HA since the iHost Bluetooth chip works with HA.
Yes, R5 should technically work locally well on HA over iHost.
As you have also noticed that the eWeLink Remote Protocol which is used by R5 is proprietory and is not publicly available. We will need to find a proper solution to integrate it into HA.
Please be patient and stay tuned, I will update if there is any progress.
Thank you very much for your feedback. Another similar use case, we will look into it.
A quick update: Node-RED Now Works on 32-bit iHost
32 bit Node-RED is now available in our add-on repository and confirmed to work on iHost.
Please, port the Matter Server add-on, to be able to connect Matter devices into HA iHost.
If possible, port the OpenThread Border Router, so we could use our iHost as Thread Border Router too
Matter Server and OpenThread Border Router are both on our list.
Hello @KwayLi99
What might be interesting for the new iHost would be PoE and possibly an M2 SATA slot.
Greetings, Paul
Thanks for your feedback. We are considering these features on iHost so pelase stay tuned!
Best Regards!
Hi KwayLi99,
I have some suggestions for the new 64-bit iHost:
  • It should have an M2 drive slot.
  • It should be PoE-powered.
  • It should be an OpenThread Border Router.
  • It should be able to install Matter Server.
  • It should be able to install Music Assistant Server.
I am glad to say we will cover all of them.
Just one question: would it be better if we bundle all these add-ons in the Home Assistant OS or do you prefer to install these add-ons manually one by one when you need them.
Will it be possible to make a backup on iHost 32 and then restore it to IHost 64?
Yes, and migrating from HA over 32 bit iHost to HA over 64 bit iHost will work like a charm.
That about migrating from Cube OS over 32 bit ihost to Cube OS over 64 bit ihost?
Are you planning to further develop and update eWeLink CUBE, or will all your efforts be devoted to HA over IHost?
We will definitely support it.
Our company is dedicated to continuing developing and enhancing eWeLink CUBE OS. There is at least one release every month.
HA over iHost (and there will also be ioBroker over iHost, etc.) doesn’t conflict with eWeLink CUBE OS at all.
will the CubeOS update be in June?
when can we expect new matter devices to be added to ihost (matter motion, presence, light intensity sensors)
