The tutorial of running eWeLink Camera Gateway using Portainer
➢Find Portainer image on Docker Hub , copy the Docker Pull Command.
➢Paste the copied docker pull command on console window.
➢Run Portainer on port 9000
➢Access to Raspberry Pi :9000, set the username and password.
➢Successfully set! choose local docker environment to connect Portainer.
➢Install eWeLink camera gateway
➢Successfully pulled.
➢Set a container for camera gateway
➢Start the configuration
➢Deploy the container
➢eWeLink camera gateway is ready!
➢Access to cameragateway.local:8606, log into your eWeLink account and add camera.
