Hey,
Thx for catching up!
You can sync sensors with eWeLink via Matter Bridge in eWeLink CUBE/iHost and Matter Hub (NSPanel Pro or CAST tablet app).
For the Matter Hub feature in iHost, I can not share more at this time.
Hey,
Would it be possible to connect the iHost Matter Bridge to the Cast app?
I’ve seen this in the past but I still haven’t figured out how it works.
Yeah, but it’s not as stable as NSPanel Pro, to be honest. It could use some safe fail measures to keep it running in the foreground.
Do I need a subscription to use the cast app?
Pero para eso se necesita tener un hub adicional como el zbbridge ultra, si no, no funciona. No se puede agregar un dispositivo matter a ewelink si no hay hub y el ihost no cuenta en este caso por que seria el dispositivo a agregar..
