How I integrated switchman R5 remote in google home using ihost and google nest hub
Miniguide: Using the Sonoff SwitchMan R5 to Control Google Home Scenes
After a couple of months of owning the Sonoff SwitchMan R5, I struggled to find a way to integrate it into my smart home setup effectively. Since I primarily use Google Home for routines and light scenes, I decided to write this guide to help anyone else facing similar challenges.
Step 1: Link the Matter Hub to Nest Hub
  1. Open the Google Home app and use the “Add Matter Device” option to link your Matter hub.
  2. In the iHost interface, complete the pairing process.
When done, it should look something like this:
Step 2: Create a Virtual Switch in Node-RED
To enable scene control, create a virtual switch device in Node-RED and add the necessary code to control the newly registered virtual device. Here’s how:
  1. Set Up the Flow:
The entire flow should resemble this:
  1. Register the Virtual Device:
• Use a UUID generator (e.g., Online UUID Generator Tool) to create a unique identifier.
• Fill in fields like IP, name, and firmware with random values. For simplicity, I copied the node details from a Tapo light bulb.
Example:
  1. Flow Logic:
The magic happens in the last part of the flow. It monitors the state of the R5 switch and updates the virtual device state when a specific button is pressed.
Here’s how it looks in practice:
  1. Optional Delay:
I added a delay in the second row of the flow to turn off the virtual switch after 5 seconds. This is because I use the virtual device solely to trigger a light scene in Google Home.
Step 3: Add the Virtual Device to Google Home
Once the flow is configured, the virtual device (e.g., vd-sw-MaxLight) will appear in the Google Home app.
  1. Go to the Automations tab in Google Home.
  2. Add this virtual device as a starter for your desired scene.
Here’s how it looks:
The scene activation delay is around 1–2 seconds, which I found perfectly manageable.
Final Thoughts
This solution has made the R5 much more useful in my Google Home setup. I hope this guide helps others facing the same issue. If you have any questions or improvements, feel free to share them below! :blush:
Nice guide :dizzy:
I think the experience would be better when Google decides to optimize compatibility for Matter Generic Switches.
