Home Assistant on iHost
I have been using Scene in both eWelink and also in iHost (but apparently, those two are completely different animals), but in spite of that, I have found them very useful, and fairly easy to use.
However, now I’d like to try using Home Assistant on iHost. I found a good YouTube video (https://www.youtube.com/watch?v=OhugPsohwjE&t=116s) on this, which I followed, and Home Assistant now seems to have been installed properly within Docker, but I then can’t open the WEB Page to access Home Assistant.
Has anyone had any issues like this, and could point me in the right direction?
Also, do I need to install “HomeBridge” for this to work, and if so, what would be the process.
Thanks in advance for any help you can give.
What do you mean?
For what to work?
I think he’s having trouble accessing to Lovelace of Home Assistant.
@giles.baxter can you tell us how you try to access it? http://ihost.local:8123 or another port you mapped?
Firstly @giles.baxter should make sure his Home Assistant instance has a hostname set. But provided that he has it set, he should type in the hostname followed by .local:8123. For example, if a Home Assistant device is named homeassistant, you would enter http://homeassistant.local:8123. If the .local domain does not work, one may need to configure the devices to recognize the hostname by editing a hosts file or using a local DNS server. For HA in a container (docker) the situation may be different → go to http://<your-server-ip>:8123 to access the Home Assistant web interface.
It’s possible to access the interface of HA instance by entering the IP address of your Home Assistant device, followed by the port number (usually 8123). For example, if one’s Home Assistant IP address is 192.168.1.10 , one would enter http://192.168.1.10:8123 .
No, it’s not needed for anything. Home Assistant is a local server and works without additional third party software.
Thanks for that, but I had already tried those addresses.
My iHost’s IP address is 192.168.0.11, so I added the “:8123 to the end, but that page couldn’t be reached.
In that YouTube video (https://www.youtube.com/watch?v=OhugPsohwjE&t=116s), it shows the Port as “1233, 80”. Could this be the issue? When I try using 192.168.0.11:1233, it opens a page at " HomeAssistant-files - Files - File Browser” which shows the actual files, but not the HomeAssistant GUI.
Is there a way to check and edit (if necessary) the Port settings in the iHost?
I also checked the LOG as well, and it is showing multiple errors, all:
“2024-10-23T09:00:01 exec /usr/local/bin/hass-cli: exec format error”.
What would cause this?
Because it is meant to open your File browser! This is not the same.
Did you make sure that your Home Assistant instance has a hostname set? It has to be set since your running HA in a headless mode. You need to access your installation through web-based interface. Did you do the installation exactly as shown in the instructional video? If you are not sure, delete and start again. Take notes before you start, paying particular attention to the name of the directory where HA will be placed. And finally, run your HA instance.
You may want to try this when installing anew: https://github.com/hacs/integration/releases/latest/download/hacs.zip.
I did install as per the video, twice. Maybe the third time will be the one.
Thanks again for your assistance.
Hi Giles, I was able to install Home Assistant with no further issue, out of the Docker repository. When launching Home Assistant for the first time from ihost → docker in the properties dialog, just choose HOST network type. No need to set port or anything else.
After a couple of minutes, you could try connecting to http://ihost.local:8123 in my case, I am using Chrome under Windows and had to change the configuration of SITE SETTINGS, allowing to launch EMERGING WINDOWS OR SITE REDIRECTS and to allow INSECURE ACCESS (this to allow Chrome to connect over non encrypted HTTP trafffc), without changing that was not possible to connect to Home Assistant running within iHost.
Hope this helps…
I also was able to install HA in my ihost and access the web interface.. My issue not is, when I am installing ZHA, im getting a ‘failed to connect’ message when I use the ‘/dev/ttyS4’ in the serial path… not sure why. Has anyone encountered this?
Check if Zigbee2MQTT has been deactivated, Zigbee2MQTT and ZHA cannot be used at the same time
Can I install home assistant on iHost via docker and export zigbee device from IHost to Home Assistant and use them both and in IHost and in Home assistant?
No, you can’t.
Hi Jemma, also struggle with same topic. How do you deactivate the ZigbeeMQTT in Home assistant?
You can’t “deactivate ZigbeeMQTT in Home Assistant” because such a thing doesn’t actually exist.
Home Assistant doesn’t include anything called ZigbeeMQTT. What you’re probably referring to is Zigbee2MQTT, which is a completely separate add‑on that HA only talks to via MQTT.
If you want to stop it, you don’t disable anything “in HA” — you simply stop or uninstall the Zigbee2MQTT add‑on in Supervisor → Add-ons, or stop your MQTT broker if you want to go nuclear, or remove the MQTT integration if you want HA to stop listening entirely.
Think of it like asking “How do I turn off the oven in my fridge?” You don’t — because the fridge never had an oven. They just happen to live in the same kitchen.
