Extending Zigbee Network On The Ihost
Just a quick question about Zigbee Network Extending, Will it only extend through one repeater or can multiple repeaters chain together to cover a greater distance, as displayed in my rough sketch below
As far as I know Zigbee supports multiple repeaters to create a mesh network. And based on your graph above it is already happening.
I need to create a network extending like this one.
What do you suggest me to buy? There is a compatibility list?
My root is a IHost.
Thank you very much!
Sonoff ZBMicro, S series Zigbee plugs, 06P sensor, or basically any cheap standard Zigbee 3.0 lights or switch (with neutral wire).
IKEA has a discontinued Tradfri repeater, too, but its signal strength seems to be weaker.
It would be nice on ihost if it showed the mesh of the network. today it only shows the direct links with ihost. it does not show the connection between equipment. sometimes a sensor is not connected directly to ihost and it appears loose on the map. but it continues to work correctly this for both end devices and router devices.
