Does SONOFF Ihost need a range extender?
How can I connect devices that are not near the IHost?
Has anyone got recommendations?
You need a zigbee network repeater like this one
https://a.aliexpress.com/_mNkl1Xw
You can also use this switch that works as a repeater, it’s cheaper and you can use it to turn on/off something remotely
https://a.aliexpress.com/_mNbqfFi
How to install a zigbee network repeater in a zigbee network? I am asking about zigbee network repeater “small USB stick” without setting?
Can a Sonoff zigbee USB dongle (router) be used?
Something like this work as a repeater with iHost out of the box. You need to check in iHost Ziggbee2Cube to discover it.
https://pl.aliexpress.com/item/1005005237544544.html?spm=a2g0o.productlist.main.5.2bc22884j83W4P&algo_pvid=fc042594-d588-4877-aa83-ee2012aabf13&algo_exp_id=fc042594-d588-4877-aa83-ee2012aabf13-2&pdp_npi=3%40dis!PLN!26.48!26.43!!!6.54!!%402100b69816896904616261268d077c!12000032317817792!sea!PL!700680790&curPageLogUid=VcEbHs1qAvCq
Zigbee Dongle-E (flashed with router firmware) works as well but it is discovered as a light.
Thank you!
