eWeLink Moble App on Samsung Android 7
My eWeLink App does not function anymore on Android 7. Someone told me that now it should be Android 8 or up. Since my mobile android version cannot be upgraded, I cannot use all Sonoff devices. This I find unacceptable. Do I have to buy a new mobile with an Android version higher than Android 7. I expect that eWeLink App that works on Android 7 is still available.
I brought this up a long time ago, right after this change was introduced. Nothing has changed and will not change.
The current version of the application requires Android 8.1 and higher.
The latest version of the application that can be installed and run on Android 7 is probably 5.4, but this version does not have full functionality and many things do not work because it is not supported on the server side!
The only options are a device with Android 8.1 and higher or eWeLink WEB ($10/y) which can replace the application to some extent but not 100%.
There is no other option and probably will not be.
The full functionality of the application cannot be obtained in any way either through the WEB version or the older version of the app, only a newer Android…
PS
I have no idea if eWeLink provides old versions like 5.4 anywhere, you have to risk some other application source apkmirror / apkpure.
