eWeLink CUBE Version 2.4.2 , Effective Period resets to Everyday 24 hours
After upgrading to eWeLink CUBE Version 2.4.2, the Effective Period resets to Everyday 24 hours after setting scene OFF and then ON.
To recreate,
  1. set Effective Period of a scene to custom defining a custom time range.
  2. save the scene
  3. disable scene status to OFF
  4. check scene settings, it and it reseted back to Everyday 24 hours!
Indeed, that is the case.
I have exactly the same anomaly.
When deactivating a scene with a custom time period and reactivating it, the time period is changed from custom to 24 hours.
This is a defect that must be resolved.
Thankyou. Greetings
@SuiKa New Year is already over, wake up please )
Scenes are broken in firmware V2.4.2
I confirm the error. Disabling the scene resets the time settings
Just getting my body out of the holiday mood, slowly.
Can you provide any system log?
And with some detail about “broken” will be more helpful.
Comfirm it, too.
We’ll pinpoint it ASAP.
When will this bug be fixed?
A patch should arrive as soon as the next monthly version.
Will the March update be around the 15th or at the end of the month?
Ewelink Cube v2.5.0 - The bug has been fixed.
Indeed, the error when deactivating a scene with a custom time period is already solved.
Thank you
