Matter Hub lets you easily add, control, and manage Matter-enabled devices locally using the eWeLink CUBE.
Currently, in beta, we support:
- Matter plugs and on/off switches that work with the [On/Off Plug in Unit](Supported Device Types - Matter) device type. And we will keep expanding the list to cover more devices.
- Matter Lights, including
- On/Off Light
- Dimmable Light
- Temperature Light
- Extended Color Light.
Please kindly note, that Matter device manufacturers may use different standards. For example, Hue uses On/Off Light for smart plugs. If you’re unsure about compatibility, it’s best to check with the vendor directly.
Here’s a detailed chart showing what’s supported by eWeLink CUBE’s Matter Hub feature:
