It started with a conversation
Back in January, we shared
and invited you to vote on which areas mattered most to you. The conversation covered everything from bringing more devices into Matter to making everyday setup and local control easier.
As 2026 draws to a close, we’d like to return to that conversation: what has shipped, what we’re working on now, what we’re planning next, and what you would like us to explore in 2027.
Whether you’ve been running CUBE all year or are just discovering it, thank you for being part of this community.
What we delivered in 2026
1. A more capable Matter Bridge
We upgraded the Matter Bridge SDK to v1.5.0 and expanded support for bridging more Zigbee device types to Matter-enabled platforms via Matter Bridge, including:
- Flow Sensor
- Rain Sensor
- Soil Sensor
- Air Purifier
- Pressure Sensor
- Siren
Beyond these device types, Matter Bridge supports video and audio streaming from eligible cameras and exposes energy metering data from connected Zigbee devices.
2. Simpler SONOFF Dongle setup and firmware management
CUBE can detect connected Zigbee dongles and lets you flash supported SONOFF Dongles with the recommended stable firmware in one click. This now includes Dongle-PP10, which can also be used as a Zigbee router.
3. Add eWeLink-supported devices without extra add-ons
With the built-in “Add eWeLink-linked Devices” feature in CUBE, you can sign in to your eWeLink account to sync and manage eligible eWeLink-linked devices without installing the separate eWeLink Smart Home Add-on. That’s one less setup step between your existing devices and CUBE.
4. Easier installation
Docker deployment added another flexible way to run CUBE on your own hardware. We also introduced one-click installation for Windows and Mac, making CUBE easier to deploy across a wider range of hardware.
5. More native Matter device types in Matter Hub
Matter Hub gained support for more Matter device types, including:
- Temperature Sensor
- Contact Sensor
- Occupancy Sensor
- Light Sensor
- Air Quality Sensor
- Smoke CO Alarm
- Generic Switch
- Dimmable Plug-in Unit
This gives you more options for adding Matter devices directly to CUBE as a Matter controller, alongside the devices you expose to other Matter platforms through Matter Bridge.
6. More useful local records and energy history
Energy-monitoring improvements brought bidirectional energy readings and up to 12 months of history on supported hardware; availability depends on the device. Tamper-alert event logs also made it possible to look back at recorded events locally.
Beyond these six highlights, local scenes gained more trigger options, including power-consumption ranges and external switch events from supported devices. CAST also gained a dynamically adjusted temperature chart axis and white and color light controls for compatible lights.
Together, these improvements address several of the priorities discussed in January. Some of the broader goals still need more work, and we want to keep that distinction clear as we look ahead.
What we’re working on now
- Expanded device support: Work continues on support for devices including door locks and water heaters.
- Device integration and Matter Bridge architecture: We’re reworking CUBE’s device integration modules and Matter Bridge foundations, and upgrading to Matter Bridge SDK v1.6.0.
- Expanded Matter compatibilities: We’re working to make low-battery status available for use in Google Home automations, add device fault and self-test states for carbon monoxide alarms, and support adaptive lighting on compatible lights.
These efforts are still in progress and have not been released. We’ll share release details once they are confirmed.
What we’re planning next
- More Matter device types: We plan to add support for:
- Video Doorbell
- Doorbell
- Intercom
- Electric Meter
- Heat Pump
- Robotic Vacuum Cleaner
- Thermo Plugin support: Thermo Plugin (virtual thermostats) is part of our future feature plans.
- Separate cards for multi-channel switches: We plan to let you split multi-channel switches into separate device cards, making it easier to view and control each channel.
- Cross-platform compatibility: We plan to refine device mapping to different Matter-enabled platforms, with the goal of improving available controls, status information, and automation options where supported.
These are current planning directions, not release commitments. They do not indicate that development has started or that a release is imminent. Scope may change based on research, development, and testing. We’ll share more when there is confirmed progress.
What should we build in 2027?
Tell us what to build in 2027
Leave a comment with the feature or improvement you most want, and a little context about your devices, platforms or the problem you’re trying to solve.
This is early input for 2027. We’ll review your suggestions before formal planning begins. Thank you for helping shape CUBE’s next steps.
Try CUBE on your own hardware
New here? eWeLink CUBE is free self-hosted smart home software that bridges supported eWeLink Wi-Fi devices and Zigbee devices across multiple brands into Matter.
Try it, tell us how it goes, and help shape what comes next. Thank you for spending this year with CUBE.
