I’m running a couple of Dongle E with router firmware, both show up as light bulbs which is apparently normal.
My issue is, they don’t show the signal strength and there is no zigbee map so finding the ideal location is proving to be very time consuming. Is there any other firmware that could be used? The zbmicro or slzb06p firmware would be ideal but I can’t find anything ![]()
Is this with the coordinator of the Zigbee network an iHost, NS Panel Pro or ZHA/Zigbee2MQTT?
If you have node red installed and select “all” what does a debug node say?
I don’t have that specific device but nothing I have does not have an RSSI or not appear on the maps and I’ve got two routers.
Sorry, I should have said what I was using it with. It’s connected to a Zbbridge P and I’m using the eWeLink app
