Zb net diagnostika
I’ve been having big problems with my ZB device lately. And I can’t exactly determine if it’s a network problem or some problem on the Ewelink side. Instead of a roast meat watchdog, I would appreciate and not be the only device to diagnose the ZB network.
As far as I know, the user of the application has no way of ensuring which devices are connected where, whether everything is fine, and whether they are sufficiently baptized
What kind of issues do you wish to diagnose via the eWeLink app?
signal strength.
identify which devices are connected to a particular router.
network response.
throughput.
to build a robust network and minimize outages. better deploy repeaters
You are asking for a zigbee map then?
Yes, something like that
I think this has been discussed in another topic.
It’s more of a feature of gateway firmware. Some chipsets inside the gateways may not have the capability of saving all the routing/LQI values.
SONOFF has recently released basic LQI features for certain gateways, for the Zigbee map, I’m not sure if @Staff-of-SONOFF will add the features.
Yes, I believe it is possible that the “Sonoff bridge pro” gateway hardware cannot do this, but that is why I would appreciate a diagnostic unit that could do this with ewelink web support instead of a meat thermometer.
Waiting for sonoff to implement, if possible, some kind of zigbee map/LQI features I would suggest a simple workaround using what we already have at our disposal in eWeLink. Every device connected to a bridge (i can see it in both Zbbridge-p and zbbridge-u) has a signal strength that you can see when you enter in the device option menu. It would be useful to be able to see a kind of “devices signal strength” list all in one place, maybe in a submenu of the zbbridge-p/u options. You click there and voilà a list of all of your devices with their names and signal strength. Even if you still don’t know to which router they are connected at least you can see at a glance if some devices have weak connections. In a single view all your devices and their signal strength behaviour in real time. Maybe this view could also be sortable by name? Room? Signal strength? What do you think about it?
