I installed for testing a few times Home Assistant, deinstalled it, deletet the volume, but my tfcard is now on 80 GB from 128. I have only installed essentials now, Ewelink, tasmota, nodered and tailscale.
Is there a way to clean up, with filebrowser i cant reach root directory. What is the best way?
I think to get the best support on this is go to the Home Assistant forum and ask there, you will have more change to get an awnser there I think.
check if there is volumes not deleted and delete them manually that’s related to old containers
i did, no old volumes…
please try to delete none used addon , for example home assistant if not used then uninstall it too from docker page
i did allready.
Sorry for the late reply. And thanks for trying all the troubleshooting methods.
Could you please download the logs and send them via DM?
Thx in advance.
We installed same add-on as yours.
And failed to reproduce the problem.
It might be some of the add-on’s data is too big.
You can try insert your sd card to your pc and see what file causes the problem.
On my PC the SD Card is empty, no file system errors…
What’s the system of your PC?
Both Windows and Linux.
And they both failed to recognize the SD card?
