CUBE OS v2.12.0 Now Officially Released!
This release expands device compatibility in CUBE OS and further improves the SONOFF TRVZB experience. Please take a moment to read through the notes before updating to this version.
What’s New
1.New Device Support
Added support for SONOFF MINI-ZB1GP / MINI-ZB1GSP single-channel Zigbee smart switches with electricity monitoring.
2.Expanded Matter Hub Device Support
Matter Hub now supports the following Matter device types:
- Temperature Sensor
- Contact Sensor
- Occupancy Sensor
- Light Sensor
- Air Quality Sensor
- Smoke CO Alarm
- Generic Switch
- Dimmable Plug-in Unit
3.Enhanced eWeLink-linked Device Sync Support
Eligible Zigbee sub-devices connected through SONOFF NSPanel Pro 86-Relay and Bridge-M can now be synced to eWeLink CUBE via either the eWeLink Smart Home Add-on or the built-in “Add eWeLink-linked Devices” feature.
4.SONOFF TRVZB Enhancements
Optimized the temperature graph in CUBE CAST with a dynamically adjusted axis based on temperature data.
Bug Fixes
1.Fixed an issue where a blank pop-up box was displayed when configuring temperature and humidity reporting for IKEA air quality sensors.
2.Fixed an issue where SONOFF SNZB-02M could incorrectly show air pressure comfort as out of range when no air pressure comfort range was configured.
3.Fixed an issue where the Node-RED Add-on could fail to install or update on some devices.
Guide to updating CubeOS in Docker, during the update the smart home won’t work.
Commands:
- sudo docker stop cubeos
- sudo docker rm cubeos
- reboot
- sudo docker pull https://ghcr.io/ewelinkcube/cube-os:2.12.0
I had to give the reboot command because the Raspberry Pi couldn’t start docker pull.
If everything is fine, it looks like this:
:~ $ sudo docker pull https://ghcr.io/ewelinkcube/cube-os:2.12.0
2.12.0: Pulling from ewelinkcube/cube-os
c120b97c332d: Pull complete
96c3a86e849d: Pull complete
d5dacfeb27b0: Pull complete
2f1bf0945ce9: Download complete
Digest: sha256:70328d88aac1752e03f9e8a3bbe8687ced77bbe48e3639f93f42a6c7931f9db8
Status: Downloaded newer image for https://ghcr.io/ewelinkcube/cube-os:2.12.0
For a new Docker launch on xxx, enter the account name where the CubeOS data is.
docker run -d
–name cubeos
–privileged
–net=host
–restart=unless-stopped
-v /home/xxx/data:/data
-v /run/dbus/system_bus_socket:/host_dbus/system_bus_socket:ro
https://ghcr.io/ewelinkcube/cube-os:2.11.0
If it started successfully, it will look like this output when you run the command sudo docker ps
~ $ sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ee624486c5a7 https://ghcr.io/ewelinkcube/cube-os:2.12.0 “/sbin/init” 3 minutes ago Up 3 minutes cubeos
An example of an htop output when Docker is running successfully, RAM usage is over 1 GB.
