I bought Ihost so that the alarm system would work outside the cloud. Tuya door and window sensors were compatible, except for two Tuya sirens and a Heiman remote control for arming and disarming the alarms. Follow the list below.
Hi Andy, i and @Daniel_Zhan from SONOFF team have forwarded the issue and log to dev-team, and after analyze, we have found that the device doesn’t report detect value (msOccupancySensing), that’s why you can not make a trigger by detection.
Havn’t clue why the sensor reporting without detect value, still trying to find a way to locate the root reason.
BTW, i will merge the topic you posted in this thread for better following up.
However, it does not seem to transmit any motion detection.
I have created a scene for it to switch on a ZBMini on motion detection. It does offer me ‘Motion detected’ as trigger when setting up the scene. But when trying to test it, nothing happens.
Operation log and Debug log both do not show any entries.
Hey, @andy.wolf , Log analysis found that the device doesn’t report detect value (msOccupancySensing), that’s why you can not make a trigger by detection.
In version 1.9.1 the compatibility is a bit better, the switches with more than one channels is working, but the zigbee switchs and lights still need some fundamental funcionalities like define the default state on fault or reset. This is present for all Tuya Hubs I had seen. Every time the power goes out in my house and comes back on, the lamps stay on. This is very annoying. Could you give a priority to implement this functionality?
Hey Julhio, request received,
Power on state is a great feature, but as you may know the feature is depends on the hardware and it’s firmware. Some of the devices have this feature only with their own hub paried, but we’ll have a look if we can bring this feature to eWeLink CUBE.
Hi Labik, it seems the log is missing in the ticket system, would you please send it to my email address that i send via forum message, thanks and sorry for the trouble.
Hi Labik, our development team have checked the logs and it shown that the iHost haven’t received pairing request from the device Lidl HG06104A, would you please try to pair device by the Standard way and the Zigbee2CUBE way both and send the logs to me if it’s still failed? thank you in advance.
I have two lidl led strips.Both in pairing mode. I tried to connect them via standard and zigbee2cube mode without success. I also have a hue bridge and sonoff dongle plus and they recognize strips. Only Ihost has this problem.Pls check ticket #190577.
