[Discussion] About ZigBee2CUBE and NON-Zigbee 3.0 devices compatibility
Hello.
Xiaomi WXKG01LM wireless switch is listed on Zigbee2CUBE supported devices list, updated on 27, June but it seems impossible to pair it with eWeLink CUBE Version 1.12.0.
Any tips?
Let me have a check, get back to you later.
Just clarify a bit more, we have sorted out a list of devices that theoretically should be supported by the iHost Zigbee2CUBE, but we can’t test all of them, there are so many of them.
In short, ZigBee devices, especially NON-ZigBee 3.0 devices to be compatible with and correctly displayed in the iHost web portal, there are three conditions that must be met simultaneously,
1, The model reported by the ZigBee device falls within the types supported list by Zigbee2CUBE.
2, The capabilities (exposes) reported by the ZigBee device fall within the types and capabilities supported by Zigbee2CUBE.
3, The eWeLink CUBE system has the corresponding UI capability, meaning it can display the device properly, for now, switch classes, lighting classes, and some sensor classes are supported.
In case your ZigBee device doesn’t appear as expected in iHost, please make sure to check if it is included in the supported list provided first.
If it is not listed, kindly await periodic updates as we continue to expand the list of supported devices.
If the device is listed but is not displaying or functioning correctly within iHost, please inform us by commenting on your verification result here in this shared Google spreadsheet , We will address and resolve the issue on a case-by-case basis.
Let’s do this together!
Please read my earlier post and may i know the model of the Heiman siren?
Hey, would you please send a system log to us for investigation?
Sure, what file specifically do you guys need?
I have a lot of aibridge-* folders with logs.
Brand : IOTPERFECT
Model:PM05D-TYZ, PM07D-TYZ
I saw PM02D-TYZ on the list but this models not supported. It shows only plug and when i click open it says failed to connect.
Please add thi support to. I need soo much.
Hey @rdaraujo, @sofWar , please make the Download Log Files(in settings tab) toggle enabled and re-do the pair process, then download the logs and reported to us via the feedback channel or post it here would be much appreciated.
Hi @yitie ,
Thank you for your reply and all the details provided.
The model of the Heiman siren is HS2WD-E.
Thank you,
GM
After check the supported-list that sorry to let you know the siren with model HS2WD-E is not on the list, we have noted this request and maybe we can make some progress in later updates.
Thank you very much @yitie and have a great day!
You too, Thanks for your support like always.
Hi @yitie ,
Maybe a suggestion to add even other sirens that can be connected, as I browsed the file and I didn’t find any siren.
So maybe few of this type of product (sirens) would also be great to have for all users.
Thank you,
GM
Indeed, sirens haven’t be supported yet, will discuss with our dev team to see if we can do something.
Do you have any news,
Do you need me to forward more logs ?
Why do you not just create a generic Maker Subtype so we can link unsupported things? Zigbee-to-Home-Assistant and Zigbee2MQTT both allow home made “quirks”.
Hi @yitie,
I tried to add another siren and I have the same result, it is unsupported.
This time the model is EZVIZ CS-T9C, Wi-Fi, ZigBee.
I will keep on trying to see if there is one that will be recognized.
Thank you,
GM
@yitie
The Aqara sensor RTCGQ11LM stopped working on version 1.11.1. and until now doesnt work. I already sent a lot of logs. The spreadsheet need to be updated to ¨NO¨.
The other Aqara door sesors MCCGQ11LM does not show the link quality and where is linked on the zigbee map:
And the battery level is not shown either:
Please, give more attention to Aqara devices.
These 3 sensors work for me on Sonoff Ihost:
Water Sensor: Eleopard EV-WI-03
Smoke Sensor: Heiman HS1SA
Rail DIN Siwtch : Tongou TO-Q-SY1-JZT
We happens have the same device on hand, let me check with dev team.
No more logs needed for now.
Edit,
Only the battery info is supported at the moment, the dev-team will try to add compatibility for it, let you know if we hava a schedule.
Siren is not supported types for now, have forwarded the request to the team, i’ll keep an eye on that.
