[Discussion] About ZigBee2CUBE and NON-Zigbee 3.0 devices compatibility
Just clarify a bit more, we have sorted out a list of devices that theoretically should be supported by the iHost Zigbee2CUBE, but we can’t test all of them, there are so many of them.
In short, ZigBee devices, especially NON-ZigBee 3.0 devices to be compatible with and correctly displayed in the iHost web portal, there are three conditions that must be met simultaneously,
1, The model reported by the ZigBee device falls within the types supported list by Zigbee2CUBE.
2, The capabilities (exposes) reported by the ZigBee device fall within the types and capabilities supported by Zigbee2CUBE.
3, The eWeLink CUBE system has the corresponding UI capability, meaning it can display the device properly, for now, switch classes, lighting classes, and some sensor classes are supported.
In case your ZigBee device doesn’t appear as expected in iHost, please make sure to check if it is included in the supported list provided first.
If it is not listed, kindly await periodic updates as we continue to expand the list of supported devices.
If the device is listed but is not displaying or functioning correctly within iHost, please inform us by commenting on your verification result here in this shared Google spreadsheet, We will address and resolve the issue on a case-by-case basis.
Let’s do this together!
