Disappearing of connected device without reason
Hi! I have iHost which is up to date. I bought one ZBMINIL2 and one door open/close sensor.
I’ve installed them correctly and they worked fine 3-4 days. After that the relay was disappeared from the iHost. I thought that I’ve deleted it by mistake and reconnected it again (as a first time) and voala! Everything worked fine again but on the next day the relay was disappeared again from the iHost.
Is it possible to be a bug in iHost? I have no problem with the rest of connected devices to iHost.
I am having the exact same issue. zbminil2 connection is fine on setup then at random times just disappear. I am using the ewelink bridge to stay compatible. What is very strange is this happens with any zbminil2i installed at this location, 100% it’s wired correctly. Going to try and use Echo bridge and see if that helps, process of elimination.
