Differentiate ZBminiL2 activation
Would it be possible to differentiate the activation mode of the ZBminiL2?
In a given scenario, could we differentiate whether it is activated by the physical switch or by a program?
What do you mean? What do you want to achieve?
If I press the physical switch, it turns the main light on or off (reverse) and a second light programmed to turn on.
If I then only want to turn off the main light, how do I do that?..
If I send a command to the ZB Mini, the scenario for both lights is activated.
