Current Firmware of ZBBridge and ZBBridge Pro
Is someone could share Firmware & EWL version of their SonOff ZB bridge ? Thanks you.
Mine :
ZBBridge
FW : ZBG-AB0-GL
EWL Version : 1.7.0
ZBBridge Pro
FW : SN-NG-ZBP-01
EWL Version : 1.5.0
Idem, same fw
Hello, I don’t know how upgrade the FW. Or throug the usb port but it is not a normal operation.
The ewelink version is upgraded in the ewelink application.
I just receive a new ZB bridge pro and from factory ewl version is 1.2.0 and app propose me to ugrade to 1.5.0.
What IS your current firmware ?
Bridge Pro firmware 1.1.0, will NOT update to 1.5.0
Ok there is a problem with your module. Create a ticket , Sonoff will remotely connect to check the module.
If they also fail to update to module , Sonoff will send you a new module free
Strange, 2 days ago, Sonoff sent me a new one.
Thé module is cheaper
Yes we also Ask me a vidéo recording of the Pairing process :wink:.
And finally send me free thé module which cost 30$.
So , i am satisfied with their support.
Jak cofnąć aktualizacje?
Po aktualizacji na 1.70 nie mogę dodać więcej urządzeń niż 11
I guess this can’t be done…
a co może być przyczyną, że nie mogę dodać więcej niż 11 urządzeń?
I don’t know, some bug, configuration error… Restart to factory settings and add again.
If there is still a problem, report the ticket in English.
https://forum.ewelink.cc/t/please-raise-your-ticket-via-the-help-center-if-help-needed
