Hi, I’m new to this and I would like to receive some advice from all of you.
Currently, I have a Google Nest Thermostat Learning (I’m from Spain, so I have the European version with only 2 wires) connected to my gas boiler. However, I would like to replace it with a Sonoff NSPanel Pro and use it as a thermostat. Additionally, it would be nice if I could connect the panel to my A/C.
I’ve read about relays, but I’m a bit confused, as I’ve never worked with them before. I’m unsure if it needs to have Wi-Fi, eWeLink, Zigbee… If I have to choose, I prefer something that does not rely on the cloud and can operate on my local network, but I’m open to any option.
I believe I need to purchase the Sonoff SNZB-02 to control the room temperature, but I’m not certain.
I would prefer to exclusively use Sonoff products to avoid mixing different brands, and I’m uncertain if I also need a hub or similar device to control everything.
If you can assist me with this, I would be very grateful. Also, if you could explain how to connect the wires (in the cases where it is needed) with some diagrams or something similar, I would appreciate it.
In the future, I plan to incorporate light control as well, but that will be a later addition after I’ve successfully connected the gas boiler and A/C.
Thank you in advance!
