If it were possible.
They could add support for this sensor.
I have already added it to iHost and no entities were exported.
Even if the presence sensor would not work, if the light sensor were, it would already be a step forward.
Device Information
RSSI –
Device ID: 0xa4c13864249e9ae2
Manufacturer: _TZE204_ztqnh5cg
Model: TS0601
I am sending my iHost log.
This was the model I found that uses 24G in Zigbee2Mqtt: Tuya ZY-M100-24G control via MQTT | Zigbee2MQTT
However, I found others using the information: TS0601
ward
August 9, 2024, 6:33am
2
@SuiKa Mind taking a look at this device? Tuya may use certain modified clusters for presence states.
SuiKa
August 9, 2024, 6:40am
3
Which z2m link is the device you possess?
Do I think that’s it Tuya ZY-M100-24G control via MQTT | Zigbee2MQTT
I remember when I used it on Z2M it was recognized as a variation of that sensor.
I have another sensor of these da tuya that also does not have any entity.
SuiKa
August 9, 2024, 7:26am
5
With no entity means nothing shows on your device control modal?
SuiKa
August 12, 2024, 2:24am
7
Please send us your system via feedback or message.
We’ll check what’s wrong.
I sent the log via feedback.
ID214837
This is the Feedback number
SuiKa
August 15, 2024, 7:11am
9
The device is not supported for now.
We’ll upgrade to support it in a month or two.
