Hello dear community,
I am experiencing the following problems. Cube OS V2.9.0 in a RasperryPi 4 does not like my ZBDongle-E in Zigbee v. 8.0.2. It recognises the stick, but the auto-configuration does not work and the manual configuration does not work either. After flashing back to 7.4.4, everything works as usual again, including the setup. Is CubeOS not compatible with the latest firmware?
And which parameters do I need to pass to the Sonoff Flasher in the CubeOS Docker container so that it automatically recognises it there and flashes it from there?
Under Volumes, I had already entered /run/udev as a parameter, but somehow it doesn’t want to work.
We will support automatic firmware updates and automatic compatibility for the dongle in the next version; currently, version 2.9.0 does not support this feature. I have forwarded the issue regarding Zigbee 8.0.2 compatibility to our development team for them to record and update. I will keep you informed of any new updates.
For Zigbee versions after 7.4.4, automatic configuration is currently not supported. You may need to manually select the Ember driver for configuration. If you accidentally selected automatic configuration during the setup, you’ll need to unplug the dongle and wait for 1 or 2 minutes (to allow the serial port to release and avoid any serial port occupation issues), then plug it back in.
