I bought a ZB Repeater type CK-BL702-ROUTER-01(7018) ID: a4800e3bbd. It works fine, but in the ewelink website it shows as “Not supported now”. In the mobile APP everything is fine. In iHost everything is fine too.
When the eWeLink website shows “Not supported now” for your ZB Repeater, it means the device isn’t currently supported by eWeLink Web only. That said, it works perfectly in the mobile app and iHost.
Also, just to clarify a common misconception: technically, there’s no such thing as a “Zigbee repeater.” What you’re using is a Zigbee router which handles message routing and network strengthening. Aside from a few extra features added by some manufacturers (like Turbo mode in certain Sonoff devices), there’s typically not much to configure or adjust for a Zigbee router.
The eWeLink Web platform is known for lagging a bit behind in supporting some devices, so a bit of patience may be all that’s needed. It’ll likely catch up in a future update.
Hope that clears things up!
Thank you for your answer.
