Using a TRV Gen2 as a physical controller to operate another TRV Gen2
It’s a crazy idea using one TRV Gen2 to control another TRV Gen2. As it stands, that’s not possible at all.
The TP-WGZBA offers this kind of control, but it requires an AC power connection and includes a lot of unnecessary features.
What I’m looking for is a thermostat control panel something with a physical knob for setting the temperature and a display that shows the current temperature from a remote sensor. Essentially, a battery powered remote control unit with a display.
Something like the TP-WGZBA, but without dry contacts and battery powered/portable.
I suppose such a device doesn’t exist, right? :slight_smile:
Not entirely. There’s currently no device in SONOFF’s lineup that fits this description. However, you might want to look at the Bosch Smart Home Room Thermostat II. It’s a battery-powered Zigbee thermostat with a physical dial and a display, so it’s quite close to what you’re looking for.
I can’t guarantee it will work with eWeLink, though. Compatibility with SONOFF’s ecosystem is a different matter, and I wouldn’t assume it can directly control TRV Gen2 valves there.
With Home Assistant, the chances of making it work are very good. There’s documentation for integrating the Bosch thermostat, and even community blueprints that can be used as a starting point for linking a physical thermostat to TRVs. You could potentially use the Bosch as a convenient room controller for one or more SONOFF valves, with HA handling the actual control logic.
The one thing worth checking separately is whether the Bosch display can show the temperature from an external sensor, rather than just its own built-in sensor. That part shouldn’t be taken for granted.
I’d like to see such a device as well. I actually suggested a very similar idea to SONOFF some time ago. They didn’t rule it out, but said it wasn’t on their immediate roadmap, as the TP-WGZBA had only just been introduced.
It looks cool, but the price is mind blowing. :slight_smile:
It is! :slight_smile:
You can find used or ex-display units here and there. The price is then not quite as shocking. Well, with Bosch, you’re mostly paying for the legacy of a German brand. Although I’m sure the quality is no longer what it was with the Bosch power tools I inherited from my father. They’re 35 years old and still going, with periodic servicing.
