TRVZB hysteresis?
Hey,
It’s not supported yet for Z2M.
The feature is currently available via ZBBridge-P and will extend to other SONOFF gateways ETA in Dec.
Here’s a vid guide from SONOFF:
This is critical functionality because controlling hysteresis is important even at the cost of a short battery life. A ±1°C hysteresis is too large, and a ±2°C temperature amplitude is not acceptable for “smart” thermostat .
When will you finally fix the hysteresis to 0.3 or 0.5 °C?
Are there any changes to the hysteresis? Winter will be over before you change the hysteresis!
Well said! And shouldn’t hysteresis be implemented before winter is over it will be time to set up (or set back) a Home Assistant better working thermoregulation for next winter (using TRVZB valves and software regulation like Better Thermostat). I really hope for a Sonoff/EweLink imminent implementation though!
Why is it so difficult to implement a better hysteresis?
I’m not even talking about PID control.
Poor performance. :frowning:
Hey there… still waiting!
Maybe at the end they are really implementing some sort of PID control before releasing some updates? Then take it easy but just give us a simple hysteresis option now! Thank you.
Our team is still working on it. expected to be released at the end of Q1.
Just in time for the start of spring. :face_with_hand_over_mouth:
Bu çok önemli bir sorun
görünüşe göre sonoff için değil :wink:
Sanırım öyle
Firmware Version 1.3.0 is Online.
99% Update-Bug is also online. Stands Hours on 99% and do not finish the Update.
No chance to upgrade Firmware now. App or Web.
:yawning_face:
I saw the 1.3.0 firmware only on 1 trvzb (i have another 5 products) but it fails the upgrade and now it seems that it is not available anymore.
Same here, one TRVZB out of 8 sees an update to 1.3.0 available but fails to update. This update is about summer DST saving time, letting TRVZB valve adjust its timer automatically (from update information).
I have one device with 1.3.0 but no hysteresis setting. The 1 degree difference is too big, this option is a must have.
Out of 10 TRVZBs, it offered me an update to 1 TRVZB and it went fine, unfortunately it doesn’t solve the hysteresis yet, only DST (hopefully). In other homes after 5 + 5 TRVZBs, it doesn’t offer anything yet. There’s about a month until the time change, so hopefully it will be installed and especially if it helps, I don’t want to redo the whole plan with TRVZB by one hour again.
Otherwise, what’s your RSSI? Instead of the previous 6x ZBMINI (RSSI from 68 to 81 and sometimes none) I covered the same area with 3x ZBMINI R2 (RSSI from 63 to 75 - better coverage, better functions, smaller - ZBMINI are retiring for me), currently I already have 5x ZBMINI R2 deployed and RSSI GOOD from 55 to 70.
We’ve been waiting!
I am really looking forward to be able to adjust the hysteresis. Its a game changer. Cant wait for the update! :folded_hands:
Aplikacja 5.14 zainstalowana . Można ustawić histereze od 1 do 0.2 stopnia . Wszystko pięknie działa . Dobra robota .
