The TRV is running out of calibration when trying to close to 0 from small steps like 1 or 2%.
So it will loose the calibration more often. I noticed this behaivor especially after using the adaptive mode.
The weekly calibration is pretty useless. The TRV will run out of calibration after 1 or 2 days. We need a feature to force calibration.
And we need a mode, where the TRV extra applies force to the motor when closing. (More current. Should be possible with a stepper motor).
I have made the same observation. For me, mostly after 1 week calibration gets lost and valves do not entirely close anymore. I had opened a discussion on the VTherm forum about it here: Phyiscal valve still open, while VTherm shows 0% open · jmcollin78/versatile_thermostat · Discussion #1749 · GitHub - and some other users had the same problems. It doesn’t look like a Vtherm issue though. It would be really great, if this issue could be addressed by some fix provided by Sonoff.
Have a look on this thread:
Im doing it like him. Just closing to like 10%, then when it has to close fully, it will go up to 100%, then go down to 0% in a full cycle. No small steps. This is working pretty great so far. No calibrationlosses.
If you read this thread carefully, you will see the valve wont open from 1%, i did a test on my radiators and i let them open percent by percent with 10minutes inbetween. And i measured the radiators incoming temperature. At 18% opening, the hot water came into the radiator. And once its startet, you can go down to like 10-14%.
I made a custom controlling script with a PI controller, and it only acts between 18% to start, then it only need to go up to 30% and down to 10% to maintain the temperature.
To close it, it just go up to 100%, then back to 0%.
+1 for this request – a calibration trigger accessible via Zigbee would help a lot.
My setup: 7 rooms with TRVZB (firmware 1.4.4), paired via Zigbee2MQTT to Home Assistant. The valves are controlled by Versatile Thermostat, which sets valve_opening_degree / valve_closing_degree directly.
I tried a workaround: once a week an automation opens every valve to 100 % for 90 s and then closes it to 0 %. It does not help – a full open/close cycle is not a recalibration, and neither is the built-in Monday-noon cycle.
Request:
- A Zigbee command or writable attribute that starts a real valve calibration on demand (same procedure as after mounting), so it can be scheduled or triggered from Zigbee2MQTT / ZHA.
- Ideally an attribute that reports the calibration result/state, so automations can detect a failed or lost calibration.
Zigbee2MQTT already exposes idle_steps, closing_steps and the limit voltages as read-only, so the data is there – only the trigger is missing.
Me and lots of us would really really appreciate this. Thanks!
Please someone at EweLink/SONOFF take a look at this request.
