【TRVZB】Firmware Changelog
I don’t doubt that your valve was just not completely secured. All my 12 valves are well mechanically secured nonetheless they keep lose calibration with or without F5 error. I use my valves with home assistant automations to direct control their open/close percentage and I assure you that a certain opening percentage one day has not the same effect the following day. One day 10% opening stop water from circulating and in a few days the same 10% doesn’t clise enough anymore. This make TRVZB quite unusable if not as on/off (0%/100%). Let’s not even talk about long requested (from me too) PID proportional control, if the valve can’t keep a fine and stable control of its opening/closing percentage you just can’t even think about a PID.
Read through the following thread and related links to learn about this problem.
