The TRVZB Cast chart view y axis always start from 0 degrees, so the differnce in temperature are almost invisible, it is shoud be an option to activate self adjustment
I have forwarded your request to the product team for evaluation and record. I will let you know if there are any updates. Could you please also provide us with some screenshots to show this?
Dear sir,
see the attached picture (TRVZB_Cast_Info.jpg) for a proposal about TRVZB Cast info box with missing Accrual (Act) and Target (Tgt) temperature (proposal in red ink). In the second picture (TRVZB_Cast_Chart.jpg) you can see that in the TRVZB chart it is not possible to evaluate temperature variation over time because the x axis always start form 0°, it would be more useful to let the chart adjust on actual chart data, let say starting from 17 to 20°.
Thank you very much for your detailed feedback and valuable suggestions. We truly appreciate the improvement ideas you’ve proposed for the TRVZB Cast interface.
Your suggestions are very practical and have been recorded and included in the feature request backlog for future versions. However, due to the ongoing development of other higher-priority features, the implementation of this functionality is currently estimated to begin in versions after June this year.
Thank you again for your support and understanding!
We noticed that in the dashboard layout of your screenshot, the 4×4 tile already displays both the target temperature and the actual temperature. You can drag the resize handle at the bottom‑right corner of the tile to adjust its size to 4×4, and it will then show the target temperature and the actual temperature.
Very kind to suggest 4x4 solution but in my case I have to many device and on mobile is already very crowded, I was looking forward a more compact solution.
