I use a water temperature sensor with a THR316D. The temperature readings are not constant but intermittent although i check with my internet router that my THR316D has always an excellent connection. What could be the reason ? Should i change the sensor ?
I have the same with th10 since 2/3 days
How often are the temperature readings updated?
It is irregular. Sometimes it reads the temperature for many hours then stops reading for an hour or 2
Does the temperature still not update after refreshing the page or re-entering the App?
Sometimes when i close and open app it refreshes other times still doesn’t
Would you please submit a feedback ticket on the App?
Hello, have the same issue.
Firmware version 1.1.0.
If no improvement by summer I have to replace because can’t trust it to control the circulation pump of my thermal solar panels.
Also I can’t show the temperature measured with the THR316D in my NS panel
In general I like the local indications with such sensors, but reliability and integrability need to improve.
Hope 2023 will bring news and updates🎉
I have the same problem
Do you an extemdor to the probe?
My thr316d did that because of the extender. I canceled the extender connections and the problem was solved
Yes i do use an extender. I can’t cancel it because of distance between power and water tank
Mouin Khanafer
The extension itself is not the cable problem but the female connection it has. I removed the male RJ9 from the probe and the female RJ9 connection from the extension is made a direct connection. Problem solved
Hi
Did you merely solder directly onto the board?
