Sonoff NSPanel Pro
Hello, I have just purchased a nspanel pro and I was wondering if there is a way to add and control only an individual channel from an sonoff 4ch pro device and not all of the channels. I only want one channel to be shown on the nspanel pro and not all of them. Thanks in advance!
I have noticed that there have a feature that allows us to separate the multi-channel devices into several one-channel devices, see the settings page of the devices, but I’m not sure if it can be selected to show in the NSPanel PRO, didn’t try yet.
Hi, I have already tried that and it’s not working… maybe Sonoff needs to add this feature with a future update.
Currently, the NSPanel Pro does not support displaying only one channel from a multi-channel device. I will forward your requirement to our product manager for further evaluation. If we have any plans to implement this in future versions, I will keep you posted. Thank you.
I too would like the option of showing just 1 channel of a light in the nspanel pro especially with the new layout options on the homepage. Would be really nice
I also beg for a solution here. I have one double TX ultimate wall switch and one tile is for kitchen light and another for the garden lights. Now, I have tho choose one or another, to put it into the Ground Level page or into Technical Areas page? I also have 3x 4Ch boxes each relay having diffrent tasks on diffrent areas (a mix of heating, lights and pumps) and also not having how to separate tasks/areas…
Later edit: And try to imagine the user’s experience: To open kitchen lights, I have to navigate x pages util I have the Swich, then I have to long press to open the switch(otherwise it will ALL ON /OFF) ant only then to select the button/action… Pretty annoying, isn’t it?
I think there probably is a solution already. I have not tried on an NSPP but on the iHost use the ‘register device’ node with the NSPP as an eWeLink Cube server to create a single channel virtual device, use the virtual device to control the single channel you want on the 4Ch Pro and display the virtual device on the NS Panel Pro. Requires an always on device to run the Bode Red Host, which I don’t think can be the NS Panel Pro without turning on developer mode and pushing Node Red over the ADB to it but if you have an iHost or Home Assistant do it there.
It’s been half a year since the NPP was only used as a clock and on rare occasions, to display an exported Home Asistant page (for which I’m grateful that the developers made it possible). Unfortunately, when I have the time, I’ll rehost it with a suitable HA launcher because although Sonoff’s solution works, it is very slow and reacts poorly to changes. I removed all Sonoff Zigbee equipment that was registered with it and moved it to an HA hub. What is worse for Sonoff, is that it lost me as a customer because once I discovered HA, I discovered the variety of equipment they accept and available at much lower prices.
