GOOD AFTERNOON, I JUST BOUGHT THE SENSOR THE ITEM, IT WORKS PERFECTLY, UNFORTUNATELY THE SENSOR IS NOT RECOGNIZED BY EWELINK CAST, AM I WRONG? OR IS THERE ANY PROBLEM?
THANL YOU
Just too new, eWelink stuff have update the list of devices reconized by Cast. I have the same situation!
Ok…i hope insert in cast…thank you
My sonoff dw2-wifi-L with id: 10015ca5e7 has firmware version 1000.2.1122 and when it reaches 90% of the update to the new firmware 1000.2.1130 it gives “update failed”.
Do you manage to upgrade the FW, mine is OK with the new one.
I just read your post, tried the update and this time the DW2-Wi-fi-L finally updated correctly to the latest version 1000.2.1130.
The ones that are still offline are the DW2-Wi-Fi, the ones without the “L”.
Thank you for your mail.
I can’t verify now, I’m not at home. Maybe later.
DW2-Wi-fi-L and DW2-Wi-fi-L now work perfectly. They keep the same name.
The scenes based on them also work, although for security reasons they should be edited, left unchanged and saved again.
DW2-Wi-fi-L and DW2-Wi-fi (without L) now work perfectly. They keep the same name.
In Portugal, all back to normal during this afternoon
Yes, at last, everything is all right now.
Yes now it is all ok…thank you
You can now ad the new sensor to cast, I allready do that.
