I have a Sonoff 4 channel pro and 2 channels are connected to 12 V irigattion valves.  How can I make a channel to stay opened for two hours and then turn off? The inching option is for max. 1 hour.
Thank you. Have a nice day
You can set a time to turn on and another to turn off.
Thank you, I’ll try it. I have tried with " delay" but not like this.
Thank you. I want to be an automatic process because I use it regularly with a pump. When the pump is on I want the valve to be opened for 2 hours
You can put an external timer on each channel.
€ 1,35 5%de DESCUENTO | DC 6-30V compatible con Micro USB 5V pantalla LED, Ciclo de automatización, temporizador, Control de apagado, relé de tiempo de retardo 6V 9V 12V 24V
Thank you. Good to know.
