Scenes Groups
As I already have 60 scenes when I need to make some adjustments it is not practical to go through them all. I suggest creating the possibility of creating groups of scenes similar to groups of devices, making the search easier.
This is a great idea!!! Thanks so much for bringing it to our attention. We noted it down and will discuss it with our team later.
Hi Peter, do you have any update on when this will be delivered?
I have too to many scenes, and I would like to group them by context.
Thanks in advance
Pasquale
please let me know if is possible to create a scene like this:
  1. if Device (Corridoio) is ON - Then turn ON Group ( Second_Corriodio)
  2. if Device (Corridoio) is OFF - Then turn OFF Group ( Second_Corriodio)
Group Second_Corridoio is: 2 device are turned ON/OFF from device Corridoio
Hey
Group is not supported to work as an action device in a scene.
The support team should be implemented it, in that way we can avoid to create a thousand scenes…
Think about 1 light, and 4 or 5 turn on/off point, now we must create 10 scenes, with group we can create 2 scenes.
If one of the group turn ON, then turn on all group
The same for turn off
2 scenes against 10
can’t agree more, while it’s up to the product/dev team to evaluate the difficulty of adding the feature @songal
i found a solution, but work only with TX Ultimate with 2 o 3 o 4 gang, not with 1 gang…it work a little better, when you turn ONn is rapidly but only the devices direct to light, the secondary device not connect to light need 1 sec to turn on, the same for OFF.
