Scéně door senzor
Hello, please advice on how to create a scene? I would like the door sensor to send notifications only between 22:00 and 6:00 when the door is opened and the siren is triggered at the same time. Thank you.Jaroslav
You can do a scene as you described if you use the DW2-Wi-Fi-L sensor. This type of door sensor has the possibility to setup scheduled arming and so the push messages will be send just when the sensor is armed.
Thank you. and will it be possible to add a siren? I need the siren to sound when someone opens the door in the evening.
Yes you can add a siren which you have to integrate into a scene. If I remember Smartwise has a siren that can be operate with eWelink.
https://smartwise.eu/products/smartwise-rf-siren-sonoff-and-ewelink-compatible-with-remote-controller/https://smartwise.eu/products/smartwise-rf-siren-sonoff-and-ewelink-compatible-with-remote-controller/
