I already reported, about 2 weeks ago, problem with this device. I wait but no1 dont respond to it. All is updated to last firmware. Device is conected to bridge pro.
I have 6 of them in use and i catch one of them showing consumption till noon and afternoon it is not showing it anymore.
Power, voltage and current are showed but not recorded as consumption. I even downloaded xls file and in it is same, not showing consumption. I catch this one by luck. Devices on other ones not consumpt electric all the time so it is hard to know if they record consumption or not.
Removing bridge pro from electricity didnt help but removing device itself from electricity helps and now it show consumption again. But this is workaround, and we need solution that will grant that this dont happen anymore.
Sonoff team are you aware of this problem?
Of course consumption from yesteday isnt there, only from now on. So this problem is problem that should not exist, it is main purpose of this device, to monitor and record consumption.
Problem is still there. I have over 40 sonoff devices, mostly ZigBee.
S60ZBTPF very often forgot to write consumption in log or showing on graph.
Common, it is main function of this device and you didnt solve a problem that is old few months, or probably from its very begining. This is unacceptable.
Solve this problem or i will return all my devices as defective. Problem is somwhere in firmware, but you need to take a lock closley, from very first to last line of code.
Probably many ppl have this problem, if not all, but they don’t know it, because problem is randomly there, sometimes it work, sometimes not.
