RF Bridge inputs not working with IHost
Hello!
I´m having problems with a RF Bridge433 and iHost communication. I did the Ewelink integration correctly (two inputs, door sensor and a T2EU1C) and both can be seeing from web.ewelink:
From iHost point of view I can see both inputs:
The problem is that when I create an scene there is no feedback from the output using T2EU1C
as input (also tried with the door sensor “Puerta Depto”), manual scene as example:
It´s like there is a communication failure that I cannot find. Both Ihost and RF Bridge are using 2.4GHz wifi as backhaul (I also tried using wired backhaul with iHost). I also tried to get feedback using Node-Red debug but again no response.
I need some here, is there a know issue here that I´m not aware of or maybe I´m doing something wrong. Again the goal is to use as input T2EU1C and one Zmini extreme to work as ouput.
Thank you very much in advance for your support ! :slight_smile:
Hi!
Please correct me if I’ve misunderstood the issue:
You added two input devices to the RF Bridge433 and synced the RF Bridge433 via the eWeLink Smart Home add-on. Both inputs are visible on the iHost page. However, when you create a scene using the T2EU1C as a trigger, the action does not execute as expected.
Could you clarify the following?
  1. Are you able to see the operation log for “My Remote” (T2EU1C)?
  2. Could you share the operation log for the scene?
This will help me better understand the issue and find a solution.
Hi!
I can see the log operation from eWelink (both app and web page) indeed. I´ll upload the logs as soon as possible.
I tried to operate a S26R2 and it worked without problem, the difference in this case it was that the scene was created in eWelink web page instead of iHost. The flow was :slight_smile:
T2EU1C → RF Bridge433 → eWelink → S26R2
In comparsion de flow that I want to work is:
T2EU1C → RF Bridge433 → eWelink Smart Home → iHost → zMini
My iHost logged itself out from the eWeLink account today. Almost all of my stuff is Zigbee so I didn’t notice. May not have happened today. Manifested as completely blank Node Red flows that I designed weeks ago and used to work. Have a look at the setting of the eWeLink event nodes. Mine disappeared. Spent ages wondering why they were blank. Then when I reconnected the eWeLink one RF device worked immediately but the next two took some time.
The issue can be resolved by updating the firmware version of RF Bridge4333
Indeed I can confirm that firmware 3.6.1 fixed the issue :slight_smile:
Thank for the support!
After 3.6.0 and 3.6.1 i have 2 copy bridge in ihost on 1 in ewelink, and no one work in node-red.
What to do?
In one copy inside 4 button, another copy empty.
What is it?
This topic was automatically closed 12 hours after the last reply. New replies are no longer allowed.
